RS485 For Hypertherms
  • thefabricator03
  • Visitor
  • Visitor
6 years 4 months ago #173224 by thefabricator03
Replied by thefabricator03 on topic RS485 For Hypertherms
rodw wrote: So maybe an adapter is not required.
What do you mean by adapter is not required?
6 years 4 months ago #173225 by rodw
Replied by rodw on topic RS485 For Hypertherms
Read the label in the picture its showing attached to a standard PC DB9 serial port on the right.
  • thefabricator03
  • Visitor
  • Visitor
6 years 4 months ago #173228 by thefabricator03
So your saying just use a DB9 male connector instead of the adapter when using a PCI card? If so I agree with that but I had the screw terminal adapter handy.
6 years 4 months ago #173232 by snowgoer540
Replied by snowgoer540 on topic RS485 For Hypertherms
I found the breakout board FAR easier as well.
Maybe just add a little section "if using a breakout board" and have the table you had before...
6 years 4 months ago #173237 by phillc54
Replied by phillc54 on topic RS485 For Hypertherms
I'll let you guys figure out what it should look like, maybe also ask Clive what helped him.
6 years 4 months ago #173282 by rodw
snowgoer540 wrote: I found the breakout board FAR easier as well.
You used to be able to get DB9 connectors that came with seperate wires and pins so you could make whatever pinout you want and just plug in an ethernet cable. I never soldered up a DB9 again! I bought from Haymans electrical wholesalers in Australia.
Time to create page: 0.861 seconds
