RS485 For Hypertherms
6 years 4 months ago - 6 years 4 months ago #173307 by snowgoer540
Replied by snowgoer540 on topic RS485 For Hypertherms
Update: I bought this one to test USB to RS-485. It should be here tomorrow, I'll test over the weekend as well, and report back. I chose this brand because it's what my RS-232 to RS-485 converter is, and that works perfect.
Last edit: 6 years 4 months ago by snowgoer540.
6 years 3 months ago #173535 by snowgoer540
snowgoer540 wrote: Update: I bought this one to test USB to RS-485. It should be here tomorrow, I'll test over the weekend as well, and report back. I chose this brand because it's what my RS-232 to RS-485 converter is, and that works perfect.
Easy testing today. USB to RS485 showed up, hooked it up, ran Phill's pmx_test.py, selected the correct port, connected with no issues, everything works as it should. I would highly recommend we add this to the appendix for people who dont want to play with serial cards (which were more expensive and required a converter, etc.).
Screenshot of what I bought:
The following user(s) said Thank You: phillc54, tommylight, Clive S
6 years 3 months ago #173556 by Clive S
Replied by Clive S on topic RS485 For Hypertherms
Thanks for testing I have found this one and seems to be the same www.aliexpress.com/item/4001038346231.ht...591356-08645-Y7bAZbY
The following user(s) said Thank You: phillc54, snowgoer540
6 years 3 months ago #173631 by Clive S
I know this is off topic here but a quick question re connecting the Ohmic probe for the HP XP 65
Re this from the manual :-
Digital output. Optional, only required if using ohmic probing
Connected to the probe enabling input
This pin is used to arm the ohmic probe
How is this actual wired ie is it 24V + to TB-3 pin 14 then pin 13 to the probe on the shield of the torch to ground (plate)
If so does in need to be in series with a resistor to limit the current.
A diagram would be helpful.
6 years 3 months ago #173635 by rodw
Replied by rodw on topic RS485 For Hypertherms
More than a diagram, its actually in the docs.
linuxcnc.org/docs/2.8/html/plasma/plasma...r.html#ohmic-sensing
6 years 3 months ago #173639 by phillc54
Replied by phillc54 on topic RS485 For Hypertherms
Clive S wrote: A diagram would be helpful.
It is a bit difficult to do that in the PlasmaC docs as there are several different ways of doing it, for instance there is the way Rod linked to plus there is the another method described in the primer using the ohmic component plus there is a method that uses a separate probe that is extended etc, etc. So all PlasmaC provides is an output and an input that hopefully will allow all these different methods to work.
Time to create page: 1.062 seconds
