For PhillC regarding PlasmaC and Z axis stuff
27 Apr 2020 07:59 #165763 by phillc54
Replied by phillc54 on topic For PhillC regarding PlasmaC and Z axis stuff
Clive,
Yes, I was thinking the exact same thing while I was doing this.
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
27 Apr 2020 08:25 #165764 by tommylight
Replied by tommylight on topic For PhillC regarding PlasmaC and Z axis stuff
Clive,
Me too while i was doing something else, like drilling and chamfering and tapping a lot of holes! :)
That emplanes a lot. Thank you for your persistence Phill.
Later i will have another go at it as i will be also tuning the dual Y axis and setting up the homing and squaring.
28 Apr 2020 08:51 #165927 by phillc54
It is still probing away happily. No errors yet...
  • Moderator
  • Moderator
28 Apr 2020 09:01 #165932 by tommylight
Sorry could not get to it yesterday, i was busy surfing that gantry ! :)
28 Apr 2020 09:06 #165934 by phillc54
No worries Tom, the machine is looking good but you need to improve your footwork a bit. ;)
  • Moderator
  • Moderator
28 Apr 2020 10:12 #165941 by tommylight
You mean a lot ! :) Been over 30 years since i was on a skateboard or ice skates, never surfed, no sea, and the ones accessible are calm, Adriatic sea.
  • Moderator
  • Moderator
28 Apr 2020 11:56 #165964 by tommylight
Found out the issue i mentioned on the original post where after tripping the probe machine will not move at all, it has to do with joints so without going into joint mode and homing again it will not move any of the axis.
Conditions: machine has reached one of the limits, errors out and shows that the limit is reached, also says fix limits and restart, but no restart is required, just change to joint mode and home again, as it is also shown in the error on the bottom right on screen.
Still can not reproduce an error with an error code i got twice, more testing.
28 Apr 2020 12:09 #165968 by phillc54
Hmm, I don't understand how that could happen. If the probe trips then it shouldn't reach the limit.
If you can do it consistently could you describe the sequence of events that cause it. Is this with the same settings, hal file and ini file you posted earlier.
  • Moderator
  • Moderator
28 Apr 2020 12:34 #165973 by tommylight
That might be due to high velocity, so it reaches the limit before it can trip the error.
28 Apr 2020 12:36 #165974 by phillc54
Is it the bottom limit, I forgot to ask before.
