For PhillC regarding PlasmaC and Z axis stuff
- phillc54
- Thank you received: 2100
EDIT: were these all probe test type probes
- Thank you received: 7501
- phillc54
Now I am overthinking it and I bet it will turn out to be simple.
Like like a long day tomorrow.
- Clive S
- Thank you received: 486
Man this is so strange. I haven't heard of these issues before and I get it twice on the same day.
Phill. I am happy to do any probe testing if you want me to do so as well.
Edit: how to I check what version PlasmaC I have "buildbot"
Go get some rest, you deserve it.
It will take another month until i can finish any of the two machines i am building, this CCP thing halted every damn thing.
- phillc54
In a terminal enter:Edit: how to I check what version PlasmaC I have "buildbot"
man plasmacPlease Log in or Create an account to join the conversation.
- phillc54
I like the images in the Extras panel...
Hmmm you noticed...@Tom,
Was messing with it, but i could not get them to do anything, except showing the greyed out picture.
More research is in order.... but i was busy actually doing some work today.
While i was there, i also gave the included extras a run, pretty damn usable and very easy to use. Respect.
Side note: did you have a chance to check this :
forum.linuxcnc.org/38-general-linuxcnc-q...elocity-fluctuations
Can you please do some test and "nor confirm nor deny" that ?
Thank you.
- phillc54
External commands need to be preceeded with a % sign.
linuxcnc.org/docs/2.8/html/plasma/plasma...de.html#_button_code
Thanks, I recently pushed a couple of changes so that holes should work properly...While i was there, i also gave the included extras a run, pretty damn usable and very easy to use. Respect.
TBH i have not seen that, I will check it out in due course.Side note: did you have a chance to check this :
Now that i re-read the whole topic again, i see why you would see that as a better way of looking at it, and i do agree with you.
I could have done that but I thought 30 (above the bottom) would be easier. Or did I misinterpret?If I wanted a 30mm probe height what is wrong with using:
bottom + 30mm which would be -86mm + 30mm = -56mm.
New users to CNC have not much info on how the Z axis is set up in mills and plasma's, so for them any way is correct, but for mill users that is .... different.
I stand corrected, it is much easier to use 30mm above material than thinking where the 0 was and how deep is now -30.
Thanks for the nudge in the right direction.
All in all, after 2 days of messing with PlasmaC, it is a very enjoyable experience.
And again, that extras panel will save me a lot of time as it is very useful for 60 to 70% of what i do personally, and 10 to 20% of what some of my clients do. Now i have to go switch them to PlasmaC, if and when this CCP s#it has subsided, as it will never be over, or at least for several years.
Just for clarity : CCP = China's CoronaVirus Pandemic, i did not make that up, seen it on youtube.
Dang i almost forgot, the retraction speed after the switch is tripped, where do i change that ?
