For PhillC regarding PlasmaC and Z axis stuff
16 May 2020 09:41 #167938 by phillc54
Replied by phillc54 on topic For PhillC regarding PlasmaC and Z axis stuff
I am using a different float setup on new machines, so the float has to travel 7mm to trip the switch + 2mm of overrun, them move up the full length plus pierce height, so that makes 12mm of retract travel on every probe.
I can have a look at that extra parameter that we discussed before. You would just need to add an allowance for the extra motion up.
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
16 May 2020 09:48 #167940 by tommylight
Replied by tommylight on topic For PhillC regarding PlasmaC and Z axis stuff
Plenty of room there, 180 to 200mm travel on Z.
Rod said it nicely, we are demanding ba$....... :)
16 May 2020 11:05 #167948 by rodw
I have often thought about this as well. Unfortunately PlasmaC doesn't know about jobs, only cuts.
I wonder what happens in HAL when you do a M30 or M2?
In fact, I wonder if you could sense the end of a job by looking for a change in motion.motion-type from non zero to zero?
It really is a pain in the wet arse!
16 May 2020 11:08 #167949 by rodw
Tommy, can you add a set screw adjuster to take up the slack? best thing I ever did by allowing me to adjust out the switch hysteresis.
  • Moderator
  • Moderator
16 May 2020 11:20 #167950 by tommylight
Yes i can, but i was more for the cut screws thing since they do use about 6 or so mm of travel ! :)
To much ??
16 May 2020 11:31 #167951 by rodw
remind me to share a photo
  • Moderator
  • Moderator
16 May 2020 11:41 #167953 by tommylight
Consider yourself reminded! :)
Photos of your Z axis ? I have seen those, more than once! :woohoo:
16 May 2020 12:32 #167963 by rodw
I thought you'd lknow better than to remind somebody at 10:30 pm after a bottle of wine. think I should blame Phill for teaching me bad habits!
The following user(s) said Thank You: phillc54, tommylight
Time to create page: 1.830 seconds
