Random arc signal lost
- phillc54
- Thank you received: 2100
08 Sep 2020 19:14 #181347
by phillc54
Replied by phillc54 on topic Random arc signal lost
Possibly but I wouldn't know how.Oh, I thought you could see them as a Moderator.
- snowgoer540
- Thank you received: 907
08 Sep 2020 19:24 #181348
by snowgoer540
No worries, incoming email.
Replied by snowgoer540 on topic Random arc signal lost
- AgentWD40
- Thank you received: 96
09 Apr 2021 18:08 #205489
by AgentWD40
Replied by AgentWD40 on topic Random arc signal lost
So I'm running a 7i96 and a hypertherm powermax 45xp and am having arc lost issues. The torch fires each time but sometimes linuxcnc throws the error. I'm using machine's arcok.
There's been a lot of back and forth in this thread. Do I software denounce or use resistors???
I'm using an older build of plasmaC, the computer doesn't have internet so updating is difficult. I can follow up with my version if needed.
If I should try software denounce can someone specify exactly the hal changes required? I tried clicking those prelim docs a few pages back but the links were no good.
- snowgoer540
09 Apr 2021 18:37 - 09 Apr 2021 18:40 #205490
by snowgoer540
First, I would encourage you to update... a lot has changed, and a lot of important bugs got squashed. QtPlasmaC is pretty stable. Something to consider. If nothing else, plasmac v.191 (assuming you are on 2.9) had a lot of the aforementioned bug fixes. If you're on 2.8 it might be time to move up.
On to debounce. Personally I would start with the software debounce. I think that for everyone who has had an issue and has a powermax, the software debounce was enough to cure it. That said, if there was still issue afterward, I would use the ceramic capacitor method as opposed to the resistor method. But more than one way to skin the cat.
I am just going to list the lines you need to add/change, you will have to figure out how to get them in there. Otherwise you could post your <machine_name>_connections.hal file and I could help that way.
Obviously change your input to suite. That should get you there.
I've seen where one user reported that 5mS wasnt enough and bumped it to 10mS and hasnt had issue since. So you may have to experiment a bit. 5mS works fine for me. I'm seriously doubt the 5 extra mS makes any noticeable difference in cut quality.
I should also mention that the delay is actually measured in servo-thread counts. But assuming you use the standard 1000000nS period, that's 1mS. Make sense?
loadrt debounce cfg=3,1
setp debounce.1.delay 5
addf debounce.1 servo-thread
net plasmac:arc-ok-in hm2_5i25.0.7i76.0.0.input-06 => debounce.1.0.in
net plasmac:debounced-arc-ok debounce.1.0.out => plasmac.arc-ok-inObviously change your input to suite. That should get you there.
Last edit: 09 Apr 2021 18:40 by snowgoer540.
The following user(s) said Thank You: AgentWD40
- Thank you received: 4155
09 Apr 2021 23:38 #205497
Replied by rodw on topic Random arc signal lost
Try changingto:
Before you do anything, then try it a bit longer if required. If debounce does not fix it then:
add a 100 ohm 10W pull down resistor to your arcOK input.
I also agree to update.
setp debounce.1.delay 5setp debounce.1.delay 10Before you do anything, then try it a bit longer if required. If debounce does not fix it then:
- phillc54
09 Apr 2021 23:51 #205502
by phillc54
If debounce doesn't fix it I would use a capacitor across the contacts as suggested by PCW.
forum.linuxcnc.org/plasmac/40819-arc-ok-...fire?start=50#191678
- AgentWD40
10 Apr 2021 07:30 #205519
by AgentWD40
Do these last two lines need to be placed in any particular order within the hal file?
- snowgoer540
10 Apr 2021 08:09 #205521
by snowgoer540
From a machine standpoint, I dont think it matters.
I just do it that way because it makes it easier for me to read later and understand WTF I was doing.
Time to create page: 0.145 seconds
