Random arc signal lost
- CBEAR
- Thank you received: 46
02 Sep 2020 21:18 #180484
by CBEAR
Random arc signal lost was created by CBEAR
I have a hypertherm powermax 65. I'm using a 7i96 with two thcad boards. 1 for ohmic and the other for torch height control. I have a problem that randomly happens when I'm running a program. When it goes to pierce it won't even spark but it will immediately give me a "valid arc lost" error and pause the program. I can try to resume the program and it might work or it might do it 4 more times before it works. The strange this is that I can hit "pulse torch" and it will fire the torch just fine. I was just wondering if anyone has any idea why it might be doing this? Again, it doesn't even flash an arc, it just starts the airflow from the torch.
- thefabricator03
- Visitor
02 Sep 2020 21:21 #180485
by thefabricator03
Replied by thefabricator03 on topic Random arc signal lost
Are you using a machine Arc OK signal or a synthetic signal?
- snowgoer540
- Thank you received: 907
02 Sep 2020 21:29 - 02 Sep 2020 21:30 #180487
by snowgoer540
Replied by snowgoer540 on topic Random arc signal lost
I’ve actually seen this same thing. I’m using an actual Arc-OK from the machine (mode 1). I attributed it to using Ohmic2 vs Ohmic3, but I know CBEAR is on Ohmic3.
Last edit: 02 Sep 2020 21:30 by snowgoer540.
- CBEAR
02 Sep 2020 21:34 #180489
by CBEAR
Replied by CBEAR on topic Random arc signal lost
Machine arc ok
- snowgoer540
02 Sep 2020 21:36 - 02 Sep 2020 21:37 #180490
by snowgoer540
I helped CBEAR set up his table, he’s also using the arc-ok input (mode 1), and is on v.169. I posted his setup files (for a different issue that we solved)
Here
Hopefully they help, but being as I’ve seen this too, I wonder if there’s an underlying issue?
Here
Last edit: 02 Sep 2020 21:37 by snowgoer540.
- phillc54
- Thank you received: 2100
03 Sep 2020 02:23 #180500
by phillc54
Replied by phillc54 on topic Random arc signal lost
Are you using Auto Volts or using Cut Volts from the material. If the latter then you need to ensure that the Arc Voltage shown in the GUI is the measured arc voltage.
- snowgoer540
03 Sep 2020 03:51 - 03 Sep 2020 03:59 #180502
by snowgoer540
I had him switch over to auto volts.
Edit: I should add that maybe this is what made it go away for me, not sure I’ve seen it since I used auto volts
Last edit: 03 Sep 2020 03:59 by snowgoer540.
- phillc54
03 Sep 2020 05:13 #180508
by phillc54
So it is still an issue with Auto Volts?
- CBEAR
03 Sep 2020 05:14 #180509
by CBEAR
Yeah, I've used both. It does it on both as well.
- phillc54
03 Sep 2020 05:20 #180511
by phillc54
You may need to break out Halscope and plot the Arc Voltage And Arc Ok.
Normally if you get a lost arc error then it has seen the arc ok and then it has lost it. It may be a noise issue. Have you done some probe testing to confirm the Z axis is at the correct height.
Time to create page: 0.156 seconds
