robertspark wrote: the voltage goes up when the torch slows because the kerf gets wider (more material has been cut / blown away than the optimum kerf width).
robertspark wrote: .... but if you lower the current in sync with lowering the feedrate the voltage "should" stay roughly the same because P=V*I.... negating the requirement for locking the torch height..... given the amperage is the bit you are changing and are holding the voltage static......
thats the theory.....
phillc54 wrote: This topic is about the QtPlasmaC release, can we please keep it to that...
