- Thank you received: 106
snowgoer540 wrote: It might be better to start pncconf, and edit it that way.
You just click on the drop down, click Axis > Tandem Axis > pick whatever suits your tandem axis, usually it's Y, so Y2 Tandem StepGen.
That's it really.
The only thing that is confusing is you may have to invert the direction for one of the Y motors. It will be listed under that Joint, but it's confusing because it's next to "Unused StepGen" then Dir Gen-B, and you can click Inv there.
I show it clicked in this view, just so you can see it, you'll have to figure out if you need it or not.
Attachment not found
txtrone wrote: This image shows Z Axis stepgen inverted, or am I losing my mind?
Yep, you are correct. This catches me out a lot as well, the DIR pin is above the STEP pin.
Homing is done by LinuxCNC, QtPlasmaC should have no effect.txtrone wrote: No dice getting Qtplasmac to home my tandem X axis. I will try installing Plasmac Monday and see if I can get that to work. I jumped the gun trying to install a beta on my first go round!
phillc54 wrote: What is it doing/not doing?
