- Thank you received: 907
Clive S wrote:
phillc54 wrote: I am plumb out of ideas Clive. It may be an idea to start a thread in another section like this one as it may get more attention.
I have done a few gantry machines without issues. It worked fine with PlasmaC.
I will try to do some halscope plots to see what's going on.
Thanks for the help
Thanks for the help
If you said this and I missed it, I apologize. But if you had a working PlasmaC configuration, why not just use this method to get to QtPlasmaC:
linuxcnc.org/docs/devel/html/plasma/qtpl...tml#qt_modify-config
Clive S wrote:
Yes. I was aware of the conversion. But the problem was if it went wrong I would be without a working machine also the linux version with Debian strech I think is quite old I had updated it to 2.9..
I have also cloned the drive. Another problem was I also have to bring another machine (300 mile round trip) up to QTplasmaC
I think I am getting there now
snowgoer540 wrote: Just took a peek at your config.
For Joints 2 and 3 (Y) you have STEPGEN_MAXACCEL at 1250. Whereas for Joint 0 (X) you have it set to 2500.
I remember when I was chasing a following error in the past, PCW had me raise the stepgen_maxaccel values. Try making Joints 2 and 3 STEPGEN_MAXACCEL match what you have for Joint 0. This could be why you can jog in X but not in Y.
It's impossible for me to say why your config for PlasmaC worked without seeing it to compare to the QtPlasmaC config you've been hand editing. Is it possible for you to post that here?
