phillc54 wrote: This is a bit OT from Clives thread but hopefully this will clear up some confusion.
QtPlasmaC was designed with the end user in mind. I don't believe that end users are interested in joints (well maybe some type of joints) , all they want to do is move the torch left, right, forward, backward, up, or down. For this reason so I decided to hide the joints and only show the axes.
rodw wrote: Kinstype=both is not in my vocabulary.
snowgoer540 wrote: These days, I also use VOLATILE_HOME = 1 (link) for each joint as well. I figure at this point, if I run into a limit switch, whack an estop, etc. the table should really be rehomed. This just forces me to not opt to skip it in haste.
I'm not sure for plasma that is a big issue because I always touch off to the laser pointer at the start of the job.
So my table moves about 19mm per motor rev or about 0.095 mm per 1.8 degree step. Worst case, you would jump to the nearest detent which is no more than 0.095/2 = 0.047mm from position or 0.002" in the old units. Its just not significant even if it jumps a few 1.8 deg steps! Once you touch off to the laser you are not going to have inaccurate parts.
Yes, it has to be anbled in the "Parameters" tab, "GUI Settings" part.Clive S wrote: Q.1 Is it possible to use the keyboard for jogging ?
Make another quick config and set it in Pncconf then just copy the laser line to your config.Clive S wrote: Q.2 in PlasmaC I used this coder for laser :
BUTTON_1_CODE = G10 L20 P1 X0 Y0 \ G54 G1 X -47.5 Y 21.296 F2000 \ G10 L20 P1 X0 Y0
I like the way this worked before. What do I put where to achieve the same result ?
Paste this into "HTML" box when selecting the color: #ffee06Clive S wrote: Q.3 Is it possible to reset the GUI colour display back to defaults ?
Use the link to the calculator in the PlasmaC documents, not sure i have seen it for QTPlasmaC so might need to be added there.Clive S wrote: Q.4 I am not sure where to put the THC encoder OV and 10V frequency's the docs says pncconf but I have altered my files so can't use that now.
Also read the same thing, no idea how for now.Clive S wrote: Q.5 I think I read some ware that the DRO could be at the top of the GUI ?
