Help with QTplasmaC
5 years 6 months ago #206269 by phillc54
Replied by phillc54 on topic Help with QTplasmaC
Clive S wrote: I thought I had clicked on the plasma encoder but I will have to find out how to add it in hal
It is a little unintuitive, you need to pick Plasma Encoder then pick Arc Voltage from the "menu". It is the only item so it looks kinda odd...
Something like this in the HAL file:
# ---ARC VOLTAGE ENCODER--- net plasmac:arc-voltage-in <= hm2_7i96.0.encoder.00.velocity setp hm2_7i96.0.encoder.00.counter-mode 1 setp hm2_7i96.0.encoder.00.filter 1 setp hm2_7i96.0.encoder.00.scale -1
With PlasmaC and axis I think you had to clear e-stop . (I have a hard wired e-stop only) Do I have to clear anything in QTplasmaC to get it running - the motors are locked ie enabled
You have Estop as an indicator so if the machine is in Estop then the indicator will be red, if it is out of Estop then the indicator will be yellow. If it does that then all is good.
How do you extract the parameters to get a new pncconf
If you have an existing .prefs file with parameters in it then PncConf will not overwrite it, nor will it touch the materials file.
If it inadvertently did then you could run cfg2prefs and redo it from your existing PlasmaC config.
5 years 6 months ago #206270 by Clive S
Replied by Clive S on topic Help with QTplasmaC
More good info. Thanks.
The e-stop led is red . I will have to look at the e-stop chain .
5 years 6 months ago #206272 by phillc54
I don't see an Estop entry in "# external input signals" in the HAL file
You need to add:
net estop-ext <= hm2_7i96.0.gpio.NNN.in
and change:
net estop-out <= iocontrol.0.user-enable-out net estop-out => iocontrol.0.emc-enable-in
to:
net estop-out <= iocontrol.0.user-enable-out net estop-ext => iocontrol.0.emc-enable-in
5 years 6 months ago - 5 years 6 months ago #206276 by Clive S
Ok
I think I have addressed all previous query's
I don't have an external e-stop linked to linuxcnc. The e-stop button drops out a relay to stop all motion.
I do though think it is an e-stop problem now.
this is what I had in the PlasmaC setup hal.
I still have the red light led. Re the invert for the Y1 axis I had it done with the motor wiring
Edit: I did invert the breakaway as it was showing activated
Edit 2: I have added the encoder code as well now it shows a voltage on the gui
File Name: QTplasma_t...0.tar.gz
File Size:10.55 KB
Last edit: 5 years 6 months ago by Clive S.
5 years 6 months ago #206279 by phillc54
You really should have a Estop connection into LinuxCNC
If you don't want to then change:
to:
net estop-out <= iocontrol.0.user-enable-out setp iocontrol.0.emc-enable-in 1
I wouldn't recommend this but...
5 years 6 months ago #206309 by Clive S
phillc54 wrote: You really should have a Estop connection into LinuxCNC
to:
Yes I agree I will put it on the to-do list B)
I can now power the machine on :woohoo:
We are getting there. I can now home X and Z But Y immediately throws A F error
I know I have not put the THC settings in yet so the display is showing around 600V
I think that I have all the settings for the Y the same as the PlamaC file that worked !!
File Name: QTplasma_t...5.tar.gz
File Size:10.68 KB
Time to create page: 0.297 seconds
