- Thank you received: 106
phillc54 wrote: Can you post a compressed file of your config.
Clive, a couple of things I see is you have:Clive S wrote: I cannot jog any motors or home the machine yet. But do see the in halshow the various sensor working ok.
I am not sure what I am missing from the hal file. The motors are enable as they are locked
I will have to have another go in the morning.
phillc54 wrote:
txtrone wrote: This image shows Z Axis stepgen inverted, or am I losing my mind?
Yep, you are correct. This catches me out a lot as well, the DIR pin is above the STEP pin.
phillc54 wrote: QtPlasmaC only show the axes, not the joints regardles of the " kinstype=both" setting in the ini file.
This is a no win situation where it confuses some folk to have 4 "axes" dispalyed when they only have three and confuses other folk who expect to see 4 "joints".
Edit:
I believe you use a THCAD for Arc Voltage. If so you haven't selected a Plasma Encoder in PncConf.
Can you confirm that the 7i96 Step0 is the X axis, 7i96 Step1 is the Z axis, 7i96 Step2 is the Y1axis, and 7i96 Step3 is the Y2 axis.
