Sheetcam and trying to generate spotting gcode.
- phillc54
- Thank you received: 2100
03 May 2021 00:49 - 03 May 2021 01:49 #207695
by phillc54
Replied by phillc54 on topic Sheetcam and trying to generate spotting gcode.
Have you tried the magic comment that creates a new tool in the materials file rather than a temporary one?
I haven't looked at that stuff for a long time.
EDIT:
I do have an idea for multiple temporary tools that I will look at down the track, although I am not sure they will be required.
I would imagine that if you had a tool in your CAM then you would want it in the materials file.
EDIT:
Last edit: 03 May 2021 01:49 by phillc54.
- crowloy
- Thank you received: 19
03 May 2021 02:02 #207697
by crowloy
Replied by crowloy on topic Sheetcam and trying to generate spotting gcode.
After fixing my .ini file so the correct number of SPINDLES was used, I have spotting working. But. If i create a file with both spotting and cutting, it will fail on the first cut attempt with the torch going down, igniting and then going up again, over and over. If I separate the two, then it works fine. I'm using the latest post file from Phil as well as the latest qtplasma. in the attached file, I seem to get to line 4090 at which point it fails.
;begin material setup
N04010 M190 P23 (45 amp 14ga mild steel material)
N04020 M66 P3 L3 Q2 (wait for valid change)
N04030 F#<_hal[plasmac.cut-feed-rate]>
N04040 ;end material setup
N04050 M5 $0(cut stop)
N04060 ;end operation #30, cutting
N04070 ;
N04080 ;begin operation #31, cutting, 1.34"
N04090 G0 X2.76051 Y3.80271
I'm actually thinking that it fails at the M5 $0 which is wrong I think. that should be M5 $2 (spotting)
The second last spotting op that succeeds has a M5 $2 in it, but the last one has a M5 $0.
N04070 ;
- phillc54
03 May 2021 02:25 #207698
by phillc54
They all seem to be cutting operations, not spotting.
You need a tool named "Centre Spot" or "Center Spot" and a drill operation, or try the sheetcam post earlier in this thread.
- crowloy
03 May 2021 22:18 #207753
by crowloy
I do have the Center Spot tool defined. And I'm using the latest post from you dated in 2021. I just uploaded the wrong file
Line 4050 is wrong. It should be M5 $2 not $0 and for whatever reason this causes an issue with my Z axis. Basically it will never go past that line.
N03890 ;begin operation #30, spotting
N03900 G0 X5.77571 Y0.33994
N03910 M65P2 (THC On)
N03920 M3 $2 S1 (spot start)
N03930 G91 (relative distance mode)
N03940 G1 X0.00000004 (tiny move)
N03950 G90 (absolute distance mode)
N03960 M64P2 (THC Off)
N03970 M65P2 (THC On)
N03980 M64P2 (THC Off)
N03990 ;
N04000 ;begin material setup
N04070 ;
N04100 M65P2 (THC On)
N04110 M65P2 (THC On)
N04120 M3 $0 S1 (cut start)Line 4050 is wrong. It should be M5 $2 not $0 and for whatever reason this causes an issue with my Z axis. Basically it will never go past that line.
- phillc54
03 May 2021 23:29 #207767
by phillc54
I am out at the moment, could you post the job file and I will take a peek when I get back home.
- crowloy
03 May 2021 23:55 #207771
by crowloy
- phillc54
04 May 2021 01:56 #207779
by phillc54
It won't open for me, I get this error messge "This file version is no lomger supported"
I am using SheetCam v7.1.12
- crowloy
04 May 2021 21:40 #207876
by crowloy
That is really weird. I was using 7.1.11 and after updating to 7.1.12, I was able to load the saved job file. There seem to be some issue's with sheetcam. If I use a drilling op instead of the center spot, I can not have both drilling and cutting in the same file. As for the Center Spot op, The last center spot does not have a M5 before the Material Setup. Therefore the M5 attempts to stop a cutting operation instead of a Center Spot operation and of course this is where linuxcnc fails. It really does not like a M5 $0 attempting to stop a M3 $2.
- phillc54
04 May 2021 23:33 #207902
by phillc54
It loads now
Try this:
The last operation you have, "Drill, DRILLING":
change the tool in that to "Center Spot"
change the "Min" and "Max" hole sizes so it covers all the holes
move that job so it is the first job
disable the "No Offset, DRILLING" operation
Try this:
- crowloy
04 May 2021 23:40 #207906
by crowloy
looks like that will work. I posted on the sheetcam forum, since I believe that the issue shown above is still a bug. Not completing the operation before changing the setup is just wrong.
Time to create page: 0.433 seconds
