Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
5 months 3 days ago #346739 by PCW
It sounds like the maybe Ethernet on the host has power management or enabled or something similar
what does:
ethtool --show-eee [ethernet device name]
report?
[ethernet device name] is the name of the Ethernet device connected to the 7I76E,
something like eth0 or eno1. You can get the device name from a the results of
the command
ip a
5 months 2 days ago #346754 by RMJ fabrication
I get command not found for some reason
5 months 2 days ago #346755 by tommylight
sudo apt install ethtool
And the network is not set up properly or not connected???
5 months 2 days ago #346756 by PCW
Yes, the network is not setup properly (no fixed IP address)
5 months 2 days ago #346758 by rodw
I did a video recently about this
5 months 2 days ago #346759 by RMJ fabrication
I installed ethtool and I am still getting command not found
Time to create page: 3.923 seconds
