Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
5 months 2 days ago #346760 by rodw
probably needs sudo ethtool
5 months 2 days ago #346762 by RMJ fabrication
sudo ethtool works
5 months 2 days ago - 5 months 2 days ago #346765 by rodw
type: sudo ethtool --set-eee eno1 eee off
this will be lost on boot so to make it permanent
type
sudo grub-customizer
open the second tab and on the line it says quiet, add: igb.EEE=0
save and reboot.
check eee is off again with ethtool
With energy efficient Ethernet enabled, sometimes your NIC has a holiday which is not good for latency
Also type man hm2_eth and follow the instructions so disable coalescing if you have not done that yet on your 10.10.10.1 NIC
Last edit: 5 months 2 days ago by rodw.
5 months 2 days ago #346766 by rodw
once all that's done, do the ping command PCW asked for and share it. It should be pretty good now.
5 months 2 days ago #346771 by PCW
The reason ethtool is not found is that it's installed in /usr/sbin/
and that's not on the default user path. (but is in the default root path)
5 months 1 day ago #346778 by RMJ fabrication
The sudo grub-customizer did not disable eee for me.
Time to create page: 4.141 seconds
