Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
5 months 19 hours ago #346821 by PCW
Do you have anther PC or another Mesa card to see which device is dropping the connection?
5 months 16 hours ago #346823 by rodw
Here is a checklist of the key optimizations required for a `PREEMPT_RT` real-time kernel on Debian, specifically tailored for network performance on interface `eno1`.
### 1. BIOS/UEFI & Hardware Level
* Disable **Intel SpeedStep / AMD Cool'n'Quiet**
* Disable **Global C-States** (C1E, C3, C6, etc.)
* Disable **Intel Turbo Boost / AMD Core Performance Boost**
* Disable **Hyper-Threading (SMT)** *(highly recommended for strict determinism)*
* Disable **System Management Interrupts (SMIs)** / Advanced Power Management
### 2. Boot Command Line (`grub-customizer`)
lastcore = the last CPU you have. say its 3 on a 4 core CPU but yours may be different
* Add `isolcpus=3` to isolate specific CPU cores for RT tasks
* Add `nohz_full=3` to enable full dynticks on isolated cores
* Add `rcu_nocbs=3` to move RCU callbacks off isolated cores
* Add `processor.max_cstate=0` and `intel_idle.max_cstate=0`
* Add `pcie_aspm=off` (disables PCIe Active State Power Management)
* Add `skew_tick=1`
### 3. Network Interface (`eno1`) Optimizations
* Disable **Adaptive Interrupt Moderation** (`ethtool -C eno1 adaptive-rx off adaptive-tx off`)
* Set static interrupt coalescing to 0 (`ethtool -C eno1 rx-usecs 0 tx-usecs 0`)
* Disable offloads causing latency spikes:
* Generic Receive Offload (`ethtool -K eno1 gro off`)
* Large Receive Offload (`ethtool -K eno1 lro off`)
* TCP Segmentation Offload (`ethtool -K eno1 tso off`)
* Bind `eno1` queues to the single dedicated, isolated CPU core
### 4. Operating System & IRQ Tuning
* Increase the real-time priority of the `eno1` threaded IRQ handlers (using `chrt`)
* Set the `eno1` IRQ affinity mask to use isolated core
* Set the system power management policy to performance (`cpupower frequency-set -g performance`)
* Disable the `irqbalance` daemon (`systemctl disable irqbalance`)
5 months 15 hours ago #346829 by tommylight
Rod, this would have been much more useful in the "driver boards" or EtherCAT or both sections, not here as OP has actual networking disconnecting, same as physically removing the cable.
I really appreciate you trying to help, but i really do not like when you point members of this forum and whoever reads this in the wrong direction.
This is the second time i am mentioning on this topic that none of that tuning will help with a disconnected link.
5 months 14 hours ago #346831 by rodw
Ooops, I saw the pings but missed the disconnect window. So to my mind, the only things that could cause this is faulty hardware, crappy network cable or a flakey power supply on the Mesa card. The Mesa power can be eliminated at this point. Time to follow PCW's advice to isolate that piece of hardware is causing it.
But the ping times are also too slow.
None of my suggestions are out of scope  of a  mesa card and earlier screen dumps showed no isolcpus was set so a lot of work to do there
5 months 13 hours ago #346834 by tommylight
Again, thank you, but again, i never ever used isolcpus in my life, yet i have over 30 machines running LinuxCNC and Mesa hardware happily, every day, on mostly industrial machines, for over 10 years.
Still, i understand that sometimes isolcpus and some other tuning can help.
P.S. that 30 above does not include over 15 PC's and laptops i own, all with LinuxCNC and used on machines with Mesa boards, and therein lies my dilemma, i have plenty of laptops that run LinuxCNC out of the box, but i can not advise on getting the same laptops as i had two of the same make and model where one was OK and the other was utterly useless. And i use USB-to-LAN adapters and switches, but i never ever advise others to do the same thing, as i am fully aware of the consequences, if something fails.
5 months 8 hours ago #346836 by rodw
How many of those 30 machines run Bookworm or Trixie? I used to think like you.  In my view its mandatory today and I get much better latency results on the same hardware I used with stock kernels back when  we used to have to compile the PREEMPT_RT kernel to run Mesa cards. One day you will strike a PC which will cause you to rethink your views the hard way just like I have.
Time to create page: 2.096 seconds
