Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
5 months 6 days ago #346638 by RMJ fabrication
5 months 6 days ago #346641 by tommylight
Did you try another LAN cable?
Is the machine and the PC grounded properly?
Use a DVM and measure between Mesa 24V GND and machine case, in AC mode, while the machine is ON, post result.
5 months 6 days ago #346642 by RMJ fabrication
I did not try another LAN cable.
The machine and PC are grounded properly.
I dont have a DVM at the moment but as soon as I get one I will measure those.
I believe this is a software issue because even with qtplasmac not running I get the disconnected error every 45 seconds
5 months 6 days ago #346644 by tommylight
Can you power off the machine and leave only Mesa powered?
5 months 5 days ago #346674 by spumco
I had a problem with a Mesa board disconnecting a couple years ago.
Turned out it was a bad/weak DC-DC power supply.  Voltage would drop intermittently, causing the Mesa to reset and I'd get the 'error finishing read' nightmare.  Looked like a network issue, but @PCW helped me diagnose it as a power problem.
Maybe double-check whatever is powering the Mesa and see if it's dodgy.
5 months 5 days ago #346675 by PCW
Also make sure all power management is disabled on the host PC
Similar issues can come from Ethernet (EEE) or PCIE power management
Time to create page: 0.537 seconds
