- Thank you received: 4
Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
- RMJ fabrication
4 months 4 weeks ago #346849
by RMJ fabrication
Replied by RMJ fabrication on topic Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
I just ordered two Mesa 7I76EUs, two Mesa THCAD2s, two Hp elitedesk 800 G1 USDT with i5 2.9ghz 16gb ram 512gb ssd, and two cat 8 ethernet cables. So I really want to keep trying until I have a working system. This is my third attempt at trying to achieve a working plasma table and so far I have only got to use my machine for five minutes at a time at most. I really appreciate the amazing support from you all
- RMJ fabrication
3 months 2 weeks ago #347716
by RMJ fabrication
- Thank you received: 4153
3 months 2 weeks ago #347737
Replied by rodw on topic Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
- Thank you received: 5334
3 months 2 weeks ago #347746
Replied by PCW on topic Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
I should note that I have a HP EliteDesk 800 G1 that could never run Ethernet cards reliably
for more than an hour or so UNTIL I upgraded the kernel to 7.x
It also requires:
disabling irq coalescing
isolcpus=3
and pinning the Ethernet IRQ to CPU 3
With these changes, I never get dropped packets even after months of uptime
with a PC used for compiling, youtube etc etc
It also requires:
isolcpus=3
- RMJ fabrication
1 month 3 weeks ago #349397
by RMJ fabrication
- Thank you received: 7491
1 month 3 weeks ago #349401
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
It clearly states to change that to manual.
Replied by tommylight on topic Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
If you used this:All I had to do was switch this setting from automatic to manual in the network settings and boom works now!
The following user(s) said Thank You: arcsynapse89
Time to create page: 0.758 seconds
