MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- pinder
- Thank you received: 128
I want to make a new gui for my PlasmaC Machine.
PlasmaC axis and gmoccapy work just fine, I just want to make an exclusive GUI. Can anyone guide me.
Moreover, other thing I want is that my system boots directly to the Plasmac, just like Pathpilot. If we want to desktop, there should be some key combination.
Pathpilot is based on linuxcnc if that can do it, linuxcnx should also.
Thanks in advance.
Update: 01/10/2020
MonoKrom is the decided name.
@KCJ is working hard in qtpyvcp.
05/10/2020
added VCP for Mill MonoKrom-Plasma & MonoKrom-Mill
You can install semi-working GUI from github
This is the result so far.
After discussions monochrome yellow is the way to go.
- Online
- Thank you received: 7150
Are you willing to share that GUI after you are finished?I just want to make an exclusive GUI.
Yes, most probably for whatever is reasonable.Can anyone guide me.
?????How i can load plasmac run tab in Plasmac.
Just add the link to "startup applications" from the preferences menu. Or if you really want to skip everything else, use the "kiosk" mode for Linux.Moreover, other thing I want is that my system boots directly to the Plasmac,
- pinder
Yes, definitely I am.Are you willing to share that GUI after you are finished?
Thankyou @tommy, you are an inspiration for the community.Yes, most probably for whatever is reasonable.
How can i load plasmac panels(config, run, preview) in qtpyvcp.?????
I will dig that up.Or if you really want to skip everything else, use the "kiosk" mode for Linux.
- pinder
- Online
Not that i am aware of, i think there is some work going on on QtVCP, but not on QtPyVCP , but PlasmaC works with Axis and Gmoccapy for now.How can i load plasmac panels(config, run, preview) in qtpyvcp.
- phillc54
- Thank you received: 2093
The PlasmaC panels are all Gladevcp panels so I doubt they would work with qtpyvcp.How can i load plasmac panels(config, run, preview) in qtpyvcp.
I would imagine that you would need to rewrite it to fit into this environment.
- Thank you received: 3860
Does Phill happen to have that on his to do list?
- phillc54
Not this Phill
Oh Bugger!
- phillc54
