MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- AgentWD40
- Thank you received: 96
27 Sep 2020 20:30 - 27 Sep 2020 20:33 #184029
by AgentWD40
Replied by AgentWD40 on topic MONOKROM - qypyvcp GUI for plasmac
I meant to momentarily change the color of the *whole* control. The yellow background of the numbers might flash green for + and red for -.changing colors wont do any good because that will be under your fingertip and you wont be able to see that.
And trust me I got pretty big hand and fat fingers, there wont be any problem. Moreover, you can get 24inch touchscreen for cheap, and you will be happy for that.
Current plasmac axis and gmoccapy UI's allow for 5 and 4 custom user buttons respectively. In my own case I have a button that runs a series of gcode commands to send my gantry to a defined "parking spot" in a particular manner. I'm sure I'll come up with more for my machine. I have another non-linuxcnc cnc router that uses cnc.js, with it I've got about a dozen custom one click "macros" that I use...what custom buttons you want?
Last edit: 27 Sep 2020 20:33 by AgentWD40.
- pinder
- Thank you received: 128
27 Sep 2020 20:30 #184030
by pinder
Still, your opinion is registered.
Its somewhat personal taste.
Replied by pinder on topic MONOKROM - qypyvcp GUI for plasmac
To late, i tend to disagree on this as all caps is considered screaming on the internet.Just a little request.
Make monokrom in capitals
MONOKROM
cheers
Pinder
But it has already been decided so i will shut up now !
- pinder
27 Sep 2020 20:36 #184033
by pinder
But adding those to main screen would be a clutter.
I will add a tab at the bottom for all these misc. things.
Now I got you. But staying monochromatic is a challenge, adding more colors is out of bounds. I hope Kurt will be able to add some kind of feedback to let you know that values are changing.momentarily change the color of the *whole* control. The yellow background of the numbers might flash green for + and red for -.
We can surely manage a new tab for that.Current plasmac axis and gmoccapy UI's allow for 5 and 4 custom user buttons respectively. In my own case I have a button that runs a series of gcode commands to send my gantry to a defined "parking spot" in a particular manner.
The following user(s) said Thank You: AgentWD40
- pinder
27 Sep 2020 20:38 #184035
by pinder
Replied by pinder on topic MONOKROM - QtPyVCP GUI for PlasmaC
This is updated svg zip for all panels
The following user(s) said Thank You: tommylight, Clive S, KCJ
- Thank you received: 7478
27 Sep 2020 20:46 #184038
You are doing a great job, so again, thank you.
Replied by tommylight on topic MONOKROM - qypyvcp GUI for plasmac
Thank you, it is a title so i can live with that.Still, your opinion is registered.
The following user(s) said Thank You: pinder
- Thank you received: 4149
27 Sep 2020 20:47 #184039
Replied by rodw on topic MONOKROM - QtPyVCP GUI for PlasmaC
Man, i gotta stop drawing enclosures and install this!
27 Sep 2020 20:48 #184040
They should be, but not sure, we need to get Phill over here.Are the cut parameters all HAL pins?
27 Sep 2020 20:51 #184041
Replied by tommylight on topic MONOKROM - QtPyVCP GUI for PlasmaC
- KCJ
- Thank you received: 267
27 Sep 2020 20:52 #184042
by KCJ
I agree Tommy, but the man has done such a nice job with the rest of the GUI, we have to let him have it his way
I did try MonoKrom, which I think looks best and might help people pronounce it correctly...
Replied by KCJ on topic MONOKROM - qypyvcp GUI for plasmac
MONOKROM
cheers
Pinder
The following user(s) said Thank You: tommylight, Clive S, pinder
- pinder
27 Sep 2020 20:53 #184044
by pinder
Thankyou, Tom and @rodw
Moderators: KCJ, Lcvette
Time to create page: 0.259 seconds
