MonoKrom - QtPyVCP GUI for PlasmaC and Mill
27 Sep 2020 04:38 #183927
by Himarc3D
Replied by Himarc3D on topic QTPYVCP GUI for plasmac
Plasmac GUI?
27 Sep 2020 04:47 #183928
by pinder
Replied by pinder on topic QTPYVCP GUI for plasmac
what about monokrom?
27 Sep 2020 05:02 #183930
by KCJ
Replied by KCJ on topic QTPYVCP GUI for plasmac
I like that.
The whole family:
monokrom-mill
monokrom-lathe
monokrom-plasma
monokrom-3d
Cheers,
Kurt
The whole family:
monokrom-mill
monokrom-lathe
monokrom-plasma
monokrom-3d
Cheers,
Kurt
The following user(s) said Thank You: pinder
27 Sep 2020 05:06 - 27 Sep 2020 05:08 #183931
by pinder
Cheers,
pinder
Replied by pinder on topic MONOKROM - qtpyvcp GUI for plasmac
I was just going to purpose the idea of GUI for all machines.I like that.
The whole family:
monokrom-mill
monokrom-lathe
monokrom-plasma
monokrom-3d
Cheers,
Kurt
Cheers,
pinder
Last edit: 27 Sep 2020 05:08 by pinder.
- Thank you received: 6285
27 Sep 2020 09:37 #183954
Thank you all, you are a magnificent bunch, took just over a week to have a working GUI.
Replied by tommylight on topic QTPYVCP GUI for plasmac
+1I like that.
The whole family:
monokrom-mill
monokrom-lathe
monokrom-plasma
monokrom-3d
Cheers,
Kurt
27 Sep 2020 10:17 - 27 Sep 2020 10:18 #183961
by pinder
Thankyou Tom.
This week i have realised that working together is a bless.
Moreover, many small things in linuxcnc need a little grinding, and they are perfect.
After this I would like to work on some other project. I am a mechanical engineer and havr some experience with electronic devices, communication.
At the moment linuxcnc need some open hardware. I like Mesa cards, but they are not easy to get a hold of in many countries (shipping, taxes).
So, ideas are welcome.
Please
+1
Thankyou Tom.
Please
Last edit: 27 Sep 2020 10:18 by pinder.
27 Sep 2020 10:35 - 27 Sep 2020 11:24 #183964
by pinder
Replied by pinder on topic MONOKROM - qypyvcp GUI for plasmac
Hi Kurt,
I was thinking if we could put a splash screen before loading of the screen.
Which users can customize like Axis has.
This can provide options for Custom Shop logos Splash.
Moreover, can we use monokrom full screen without any menu and borders?
Last edit: 27 Sep 2020 11:24 by pinder.
The following user(s) said Thank You: KCJ
27 Sep 2020 14:42 - 27 Sep 2020 14:45 #183985
For QtPyVCP to work on Linux Mint 20 or Ubuntu 20.04 before any attempts at installing it, you have to follow this short snippet on creating a dummy package here, from "detailed solution"
askubuntu.com/questions/1254347/how-to-g...hon2-on-ubuntu-20-04
Then install as per KCJ tutorial on github.
Took me bloody 2 hours to get it to work on Mint 20.
Edit:
Use this if you have "package not found" issues on Mint20
community.linuxmint.com/software/search
Replied by tommylight on topic MONOKROM - qypyvcp GUI for plasmac
Edit:
Last edit: 27 Sep 2020 14:45 by tommylight. Reason: more info
27 Sep 2020 15:04 #183986
by KCJ
Replied by KCJ on topic MONOKROM - qypyvcp GUI for plasmac
Thanks tommylight, I'll add that info to the readme. Definitely save some people some time.
I did a fresh install on the latest official LinuxCNC 2.8 ISO, and it worked without any hiccups. Hopefully that's what most people will be using.
I see there are a few style inconsistencies in your screenshot, I'll get those fixed.
27 Sep 2020 15:14 #183988
by KCJ
The command line and INI options provide a way to control the initial window state (maximized, fullscreen etc.) and options to hide the status and menu bars. I find the menu bar very handy since provides a place to access less commonly needed actions that don't warrant space in the VCP, but its easy to enable/disable depending on preference.
F11 can always be used to toggle the full screen state of the VCP.
All the Display command line options can be set in the INI instead if desired.
We can change what the defaults are if you like, its very easy.
Cheers,
Kurt
Monokrome Plasma - A QtPyVCP based Virtual Control Panel for LinuxCNC.
Usage:
monokrome-plasma --ini INI [options]
monokrome-plasma --install
monokrome-plasma (-h | --help)
monokrome-plasma (-v | --version)
monokrome-plasma (-i | --info)
Required Arguments:
--ini INI Path to INI file, relative to ~/linuxcnc/configs.
Commands:
--install Installs LinuxCNC configs, data files etc. in the correct
locations. This should always be run after updating.
Display Options:
--theme THEME The Qt theme to use, defaults to system theme.
--stylesheet STYLESHEET
Path to QSS file containing styles to be applied
to specific Qt and/or QtPyVCP widget classes.
--size WIDTHxHEIGHT Initial size of the window in pixels.
--position XPOSxYPOS
Initial position of the window, specified as the
coordinates of the top left corner of the window
relative to the top left corner of the screen.
--fullscreen BOOL Flag to start with window fullscreen.
--maximize BOOL Flag to start with window maximized.
--hide-menu-bar Hides the menu bar, if present.
--hide-status-bar Hides the status bar, if present.
--hide-cursor Hide the mouse cursor.
--confirm-exit BOOL Whether to show dialog to confirm exit.
Application Options:
--log-level=(DEBUG | INFO | WARN | ERROR | CRITICAL)
Sets the log level. Default INFO.
--config-file PATH Specify the YML config file relative to $CONFIG_DIR.
--log-file PATH Specify the log file relative to $CONFIG_DIR.
--qt-api (pyqt5 | pyqt | pyside2 | pyside)
Specify the Qt Python binding to use.
--perfmon Monitor and log system performance.
--develop Development mode. Enables live reloading of QSS styles.
--command_line_args <args>...
Additional args passed to the QtApplication.
General Options:
-h --help Show this help and exit.
-v --version Show version and exit.
-i --info Show system info and exit.
Note:
When specifying Monokrome Plasma in the INI using [DISPLAY]DISPLAY=monokrome-plasma [...]
the --ini parameter will be passed by the linuxcnc startup script so does
not need to be specified.
[DISPLAY]
FULLSCREEN = true
HIDE_MENU_BAR = true
HIDE_CURSOR = true
CONFIRM_EXIT = false
Cheers,
Kurt
Time to create page: 0.126 seconds
