- Thank you received: 81
qtvcp issues
- auto-mation-assist
7 years 11 months ago #120134
by auto-mation-assist
Replied by auto-mation-assist on topic qtvcp issues
Chris,
From your response:
"It seems you want them as permanent widgets, embedded in your stacked widget."
Yes that is absolutely correct.
I think of industrial applications where every thing is done on panels with buttons, switches and feedback that could be on a screen, button color changes or a change in a display value, and perhaps even an alarm hanging on wall that is sounding of somewhere distant.
Over time things have progressed a bit and many panels have been replaced by computer screens which caused the name of all the above items I mentioned to become the new internet computer age related term, "dialog".
I can say that I don’t like the word dialog much at all. For industrial applications there is likely a better term or terms that could be used. Can you envision yourself saying to your co worker, 'I’m going to look at my dialogs", instead off "I’m going to have a look at the status of my equipment".
That being said, when I refer to dialog it refers to a panel that has the desired information that needs to be looked at or modified by a user, and has the input capabilities that allows desired changes or entries to be made. It is also a panel that can be brought to the front in a specific location within a gui, and also be replaced in that specific location by other panels when other functions are desired to to be looked at or changed. It is thus embedded in the gui and thus part of the gui's internal panel stack.
If such a panel were to be used as floating on its own in screen space somewhere it would be considered as being a pop-up and should be referred to as being a pop-up to avoid confusion.
As an example we could have "panel_123" and "pop_up_123", same basic functions just a different name to clarify the intended use as being coded for embedded or to be used as a pop-up.
For a programmer the word "dialog" means ??
But for the user of industrial type equipment it likely means "Control panel".
Thus human engineering is a factor to consider and conflicts like this should be reduced at every level of development.
From your response:
- Thank you received: 2181
7 years 11 months ago #120137
Replied by cmorley on topic qtvcp issues
i agree with the problems of interfacing programmers/engineers/machinists.
In this case the reason it's called a dialog is that is what QT (and other toolkits) call 'pop ups'. - it's a programmers term.
There is a pretty good reason to use them - they hold information that needs to be addressed immediately or before you can do something else and the toolkit takes care of stopping the user from doing that something else on the main screen.
My idea to help this further was the focus widget that dims the main screen. (it's a little finicky to get to work). They also can popup automatically, as widgets they cannot - you must program the behavior.
Anyways I will work on making regular widgets of the other dialogs.
there is a FileManager, CamView, and a OriginOffset widget available right now.
Do you want an embedable tool change message or is the popup sufficient?
Oh mabay you are using an automatic tool changer- no dialog needed.
Chris M
Chris M
7 years 11 months ago #120139
Chris,
I’m not planning to use any pop-ups in the x1Mill gui so everything will need to be regular widgets.
I do need to be able to get a message up on screen warning that the machine was set to manual operation only and that CNC mode is not available. This is required to insure that the ball screw clamp on the Z axis gets re-tightened before cnc mode is set again. The Z axis linear glass scale is also used in manual operation mode.
As far as the F6 checks. I have done some but they have not worked for me at all so I will need too make sure that I’m using the proper configuration and the right file for the test.
7 years 11 months ago #120144
7 years 11 months ago #120145
Oh sorry i forgot i didn't tell you were to look..
Ok now we know your system is capable of dialog placement.
Clearly now I see we were thinking on two different things
In the docs I will try to make it clear that dialogs are pop up devices.
Chris M
Chris M
The following user(s) said Thank You: auto-mation-assist
7 years 11 months ago #120146
Time to create page: 0.821 seconds
