- Thank you received: 2181
qtvcp issues
7 years 11 months ago #120314
Replied by cmorley on topic qtvcp issues
To use your screen in simulation it would be convenient to be able to home it.
I did this on a test screen of yours by adding to the python command of your home selection button:
INSTANCE.stackedWidget_1.setCurrentIndex(1),ACTION.SET_MACHINE_HOMING(-1)
Chris M
Chris M
- Thank you received: 7491
7 years 11 months ago #120315
Replied by tommylight on topic qtvcp issues
I've been following this from the get go, your persistence demands great respect.
Thank you.
Thank you.
The following user(s) said Thank You: auto-mation-assist
- Thank you received: 4153
7 years 11 months ago #120318
X 2
I had to go back and read the whole thread yesterday.
Replied by rodw on topic qtvcp issues
tommylight wrote: I've been following this from the get go, your persistence demands great respect.
Thank you.
X 2
- auto-mation-assist
- Thank you received: 81
7 years 11 months ago #120320
by auto-mation-assist
Replied by auto-mation-assist on topic qtvcp issues
Ref to: "do you have a homing button yet?"
No, it has not been on my priority list just yet. I’m so used to using a machine in manual mode that the only time I use homing is in full CNC mode which is not that often. I will see what I can do about getting homing going.
Ref to: "Can you push your work to your github again, maybe I'll get a change to work with your probe screen."
I uploaded my latest this evening, still have not figured out git hub to well yet. The probing panel is there but has no defines yet. I moved the files to:
x1Mill_branch/configs/sim/x1Mill
So it would be buried to deep. I hope to have all the buttons, labels and text inputs defined in the handler over the next several days for the probing panel.
I will also make sure that any changes required to insure no labels are used as inputs. Thanks for note on that also. I was wondering about that and saw no way to select them as in or outputs like in some software packages.
tommylight, thank you for the nice comment. i have tons of patience for this kind of work and wont quit until I feel its as good as it can get, and then maybe ___ just a bit more.
I want to add that Chris is fantastic and the amount of work he has put into qtvcp should not be overlooked. He is an absolute and tremendous asset to the linuxcnc community.
The following user(s) said Thank You: tommylight, Clive S, rodw
7 years 11 months ago #120321
[quote="auto-mation-assist" post=120320
I want to add that Chris is fantastic and the amount of work he has put into qtvcp should not be overlooked. He is an absolute and tremendous asset to the linuxcnc community.[/quote]
I meant that as multiple ! Both of you, and the others that contribute to everything here.
7 years 11 months ago - 7 years 11 months ago #120343
I went ahead and got the homing simulation working and was able to test out the the mdi history panel and it works fine. I think that it will beneficial to have a way to switch between the two keyboards shown in the picture. Perhaps there is already something like that that I'm not aware off..
I will start making the def items in the handler and .ui files today for the probing panel.
Last edit: 7 years 11 months ago by auto-mation-assist. Reason: added the word "think"
Time to create page: 0.587 seconds
