- Thank you received: 327
"Origami" CNC Plasma Build - folding 1200 x 600mm cut area
- Joco
5 years 4 weeks ago #222061
by Joco
Replied by Joco on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
- Thank you received: 7491
5 years 4 weeks ago #222063
Replied by tommylight on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
That works just fine and i like the idlers being very near the beam and from above so the belt is safer from accidental grabs. Also if later you want to add another belt glued to the beam and do "servo belt" style motion, it is already set up!
Do you have the pulleys already? I buy them from "ideaformer1" on ebay, never had issues and you can get 60T + 20T + 200mm GT2 belt for something like 5$ a set. Can't beat that!
The following user(s) said Thank You: Joco
- Joco
5 years 4 weeks ago #222073
by Joco
Have the pulleys and belt. Got a 4-lead (2mm pitch) 8mm leadscrew on the way for Z and still waiting for limit/home sensors.
Machine torch turned up this week so need to startt thinking about how to get that all working with the Cutskill 60.
Busy busy busy.
Cheers - J.
Busy busy busy.
Cheers - J.
- Joco
5 years 4 weeks ago #222087
by Joco
Been a busy CAD day as I flesh out the X and Z designs. Side views of the two mounting positions possible for standard sheet work or "tube" work up ~160mm diameter. Of course with the bracket system I could increase that in the future by creating new/taller brackets.
Standard mount.
High clearance mount
Standard mount.
- Joco
5 years 4 weeks ago - 5 years 4 weeks ago #222125
by Joco
One question for those following along and any who have “been there, done that”, is the single 15mm linear rail with that single truck/bearing going to handle the loads in play during motion with that assembly on it?
As a reminder the gantry supports a cutting distance of 1260mm. Overall length of the beam is 1522mm.
Should I be considering changes to support 2 trucks? Or dual rails? Or am I starting to worry about nothing?
I would appreciate thoughts from anyone more familiar with the engineering and load performance of these sorts of things.
Cheers - James.
Cheers - James.
Last edit: 5 years 4 weeks ago by Joco. Reason: Added gantry length data
- Thank you received: 4153
5 years 4 weeks ago #222129
Replied by rodw on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
Well, that is not hard too determine. The HGR specs (found on their dimensional diagrams) include torque specs for Mr, Mp and My. These are 0.15 or 0.17 kNm (150 or 170 Nm) depending on the direction of the rotation about the carriage.
Force from inertia = m x a
So say your assembly weighs 5 kg and your acceleration is 3 m/sec/sec, your inertial force equals 15 N
If you were to use CAD to define the centre of gravity of your assembly, you could define the rotational torque applied. Lets say your CoG was 100mm (0.1m) from the linear rail, the torque would be 15 * 0.1 = .15 Nm, about 1% of the HGR spec.
So at a guess, you have nothing to worry about
Time to create page: 0.327 seconds
