- Thank you received: 327
"Origami" CNC Plasma Build - folding 1200 x 600mm cut area
- Joco
5 years 4 weeks ago #222160
by Joco
Replied by Joco on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
Heh - my hypercube parts list is for 300x300.
But pretty confident my linear rails are not MGM grade. They are proper chunky 15mm full height rails with the wide mount bearings. Heck putting the rail on is going to nearly double the weight of the gantry beam.
- Joco
5 years 2 weeks ago #223178
by Joco
Managed to prove the machine torch today as well as splice into the Cutskill's trigger circuit.
forum.linuxcnc.org/plasma-laser/41893-ci...-use?start=20#223162
- Joco
3 years 8 months ago #264768
by Joco
Back into build mode after a long break. Was up to 1am with work so filled in some waiting time getting the gantry beam sorted.
Having a decent sized mill help with accurate hole drilling. Of course a drill press would have probably achieved similar. I have seen people do all the holes with centre punch and hand power drill. I just do not seem to be able to get good results that way.
Mounted and ready to think about the carriage and drive belt.
- Joco
3 years 8 months ago #264904
by Joco
The following user(s) said Thank You: tommylight, rodw, RNJFAB
- Thank you received: 7491
3 years 8 months ago #264921
Replied by tommylight on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
Hmmm... i wonder, where did i see that type of reduction...
Very nice, thank you.
- Joco
3 years 8 months ago #265129
by Joco
i read many of Tommy’s threads, advice articles and asked some questions. Nothing new in these reduction systems. Following the well documented and proven path curtesy of Tommy. Cheers.Hmmm... i wonder, where did i see that type of reduction...
Time to create page: 1.257 seconds
