- Thank you received: 327
"Origami" CNC Plasma Build - folding 1200 x 600mm cut area
- Joco
5 years 1 month ago #221180
by Joco
Replied by Joco on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
- Joco
5 years 1 month ago - 5 years 1 month ago #221256
by Joco
Got one welded up tonight. Seems to be pretty square for a weldment. Will get the second one done, do a final skim in the mill on one face that has a weld and mount them up. Then on to the gantry.
The welds are functional and not pretty. Its what happens when you don't weld enough to get good practice. But they are stuck and for the forces they will be dealing with should do the job just fine.
Last edit: 5 years 1 month ago by Joco.
The following user(s) said Thank You: tommylight, RNJFAB
- RNJFAB
- Thank you received: 59
5 years 1 month ago #221472
by RNJFAB
Replied by RNJFAB on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
Great work James,
Its all coming along nicely.
Not long now...
Not long now...
- RNJFAB
5 years 1 month ago #221478
by RNJFAB
Hey James,
Have you started n the Z axis yet?
I'm about to make the 3 hour round trip to get some ally sheets for a few jobs and was going to pickup a bunch of plate to start on the new Z axis.
- Joco
5 years 1 month ago #221486
by Joco
So a little update.
Got the brackets all welded up. Also went back and added some more weld in to get closer to what a proper fillet on 6mm should be.
Then after maching things square the first one mounted with a sqaure on it. Think its looking ok.
I couldn't resist just laying the raw gantry beam on the new mounts. Might need a little trim.
Unfortunately not going to get any progress this weekend as have to head north to parents. But the next thing of real note is going to be the Z/X assembly. Will get into that next week.
Cheers - James.
Cheers - James.
- Joco
5 years 4 weeks ago #222000
by Joco
Update and design thinking.
Got the gantry cut, trimmed the ends square on the mill and drilled/tapped the mounting holes on mill at the same time. Need to get some shorter screws. These are getting a bit long. On the plus side it has proven that the brackets have turned out rather well.
After seeing Tommylight's X axis belt design and it confirming some rough ideas I started converting things into CAD. This helps me get dimensions right first time and get a better feel for what the assembly will look like.
So here is an early idea for an X axis drive system using belts. Still rough and still debating how to secure things together. Obviously there is the potential to leave things in the current orientation or to move it 90deg shifting the motor higher above the gantry and in line with the Z axis.
Improvements/ideas welcome. Also any abservations on limitations and things to watch out for are welcome.
Cheers - James.
Cheers - James.
Time to create page: 0.445 seconds
