- Thank you received: 327
"Origami" CNC Plasma Build - folding 1200 x 600mm cut area
- Joco
5 years 3 months ago #216288
by Joco
Replied by Joco on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
- Joco
5 years 3 months ago - 5 years 3 months ago #216295
by Joco
I think I might have a had a brain wave or brain fart. Will work on an idea and post it but I "think" I can simplify this and get easier reposioning for bevel cust.
Last edit: 5 years 3 months ago by Joco.
- BigJohnT
- Thank you received: 994
5 years 3 months ago #216345
by BigJohnT
Replied by BigJohnT on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
The limit switch looks bullet proof now.
Looking good!
JT
Looking good!
JT
- Thank you received: 4153
5 years 3 months ago #216351
Replied by rodw on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
I wonder how useful the fillet feature would be? Lets say you were cutting an end cap to weld onto a tube or square section.
How many setups would you have and how would you manage them?
If its not an end cap, there are plenty of ways to design a part to be welded without a fillet once you have a CNC plasma cutter at your disposal. eg. tab and slot construction. You can even cut the tabs shorter than the material thickness and weld from the back for a nice clean finish with no visible welds.
- Joco
5 years 3 months ago #216412
by Joco
Rod - I'm not sure its needed or necessarily useful. But just exploring it from a design angle.
The design I have at the moment is actually good enough to run with I think. Now I need to have another look over your's and Tomy's builds to see how you fixed the gantry beam to the Y axis sides. Then finish off my design for that so I can get the blanks cut up and get things processed on the CNC mill.
Cheers - J.
Cheers - J.
- Joco
5 years 2 months ago #218286
by Joco
Bit of a question today for those with more experience in this. I'm looking at the gantry sides and how they will connect to the beam that will support the X axis. I think I need to change things to allow for adjustment and probable a little more ridgidity.
So here's my hacky idea. Views, improvements and better approaches welcome!
Thanks - James.
Thanks - James.
Time to create page: 0.149 seconds
