"Origami" CNC Plasma Build - folding 1200 x 600mm cut area
5 years 3 months ago #215355 by Joco
Thanks for the advice Tommy.  I'll run with 2mm lead as I can find the locally easily (as I can with 8mm lead). I would hope that I am not dealing with so much warpage that I need to move multiple mm's in sub second intervals.  Worse case will be I "live and learn" and move to 4mm lead later after I import the needed parts.
Cheers - J.
5 years 3 months ago #215459 by Joco
Taking on Tommy's advice and inspiration from his Z design I have been redisgining the Z assembly.  This design is 46mm from front to back.It has 130mm of travel and the total height of of the backplate is 270mm. Amount of travel on the float switch is probaly around 8mm at the point of trigger.  Total physical travel is 13mm.
Interested in views, improvements or potential gotchas.
Cheers - James.
5 years 3 months ago #215465 by rodw
Looks good. The only thing to watch is to be able to adjust the float switch hysteresis but I guess you can adjust that with the bolts.
I added an adjustment screw so the float switch just moved the minimum amount to trigger for speed.
5 years 3 months ago #215469 by tommylight
Make the switch location so that the plate triggering it rests on the supporting plate when pressed down, not on the switch.
Saves some switches! :)
The following user(s) said Thank You: Joco
5 years 3 months ago #215470 by rodw
Also, I learnt the hard way, the switch should be on the fixed part, not the moving part so the  wires are not flexing all the time...
Try and design it so the switch body is safely out of the way so it can't be smashed...
5 years 3 months ago #215474 by Joco
Rod - with this design I'm not too sure how I can avoid a flexing wire situation.  Definately need to get the switch into a safe spot.  But all good refinements to look at after this first cut.
Time to create page: 0.765 seconds
