"Origami" CNC Plasma Build - folding 1200 x 600mm cut area
5 years 3 months ago #215667 by tommylight
QtPlasmaC "shouldn't" jog if breakaway, float, or ohmic are tripped.
Did not know that, PlasmaC did and i did ram the torch once testing it.
More testing ... :)
5 years 3 months ago #215670 by phillc54
Yeah, we couldn't do it in either Axis or Gmoccapy. But you convinced us it would be a good idea for QtPlasmac.
5 years 3 months ago - 5 years 3 months ago #215711 by BigJohnT
The switch needs to be mounted so you can't smash it no matter what.
JT
Last edit: 5 years 3 months ago by BigJohnT.
The following user(s) said Thank You: Joco, Coachbuilder
5 years 3 months ago - 5 years 3 months ago #215716 by Joco
I’m in the process of some tweaks as I plan to move to the roller style micro switch per JTs pic and what Rod had also shown me.  Aim is to do a no smash set up per comments.
Last edit: 5 years 3 months ago by Joco.
5 years 3 months ago #215807 by Joco
After some tinkering in CAD have these ideas for float and Z limit switching.  Uses "simple" switches that are not able to be smashed and have stops that should be adjustable to fine tune the stop trigger position.
Float switch:
Z Limit Switch:
As an aside I see the forum has a new editor look. But where the heck is the post preview?  I'm probably being blind or missing the point somewhere but can not see/find it and really missing the ability to preview a post before hitting submit.
Cheers - J.
The following user(s) said Thank You: RNJFAB
5 years 3 months ago #215818 by tommylight
Much better! :)
And shhhh about the editor, there are some angry members here regarding it ! :)
Time to create page: 0.359 seconds
