- Thank you received: 4153
"Origami" CNC Plasma Build - folding 1200 x 600mm cut area
5 years 3 months ago #215476
Replied by rodw on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
If the part the acme screw nut is bolted to was a piece of angle iron, it would be an ideal spot for a switch with minimal wire flex...
- Joco
- Thank you received: 327
5 years 3 months ago - 5 years 3 months ago #215555
by Joco
Replied by Joco on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
Last edit: 5 years 3 months ago by Joco.
- Thank you received: 7491
5 years 3 months ago #215562
Replied by tommylight on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
The following user(s) said Thank You: Coachbuilder
- Joco
5 years 3 months ago #215629
by Joco
But to get smashed switches doesnt that mean a lot of Z axis crashes? If so how? That would feel to be the sign of some kind of problem?
5 years 3 months ago - 5 years 3 months ago #215654
No problem, user error, namely while setting up the machine and it rams at full speed on the material, or sensor not wired to the input you thought it was, or jogging down while holding shift key ( PlasmaC does not react to float switch while jogging, it should ), etc.
Or after cutting some plates you find a nice design for some lights made out of square tube and forget to raise the probe height, this happened to me several times...
Last edit: 5 years 3 months ago by tommylight. Reason: Removed QtPlasmaC
- phillc54
- Thank you received: 2100
5 years 3 months ago #215657
by phillc54
Replied by phillc54 on topic "Origami" CNC Plasma Build - folding 1200 x 600mm cut area
QtPlasmaC "shouldn't" jog if breakaway, float, or ohmic are tripped.
Time to create page: 0.302 seconds
