retrofit on EMCO PC turn 55
- Thank you received: 5325
- jrkeat
I've started looking at the VFD. It's a Lenze E82EV751. (Manuals can be found for the 8200 series, if anyone cares to look.) It's incredibly sophisticated, offering all sorts of analog and digital inputs and outputs, breaking, network configuration, etc. There are pins that should allow me to to conventional analog control, but I'd like to look into more sophisticated features too.
I'd like to figure out what kind of connectors the original uses--they look to be unbranded. They resemble Molex connectors, most of them with 4 pins. All the wires are connected using are screw terminals-very nice. Also, one side of the connectors is rounded around each pin. These are also used for the VFD connections, so they might be fairly standard in Europe. I'd like to find the female connectors so that I can use all the original connectors. If anyone has any clues as to what they are or where I could find them, I'd appreciate your input.
- Thank you received: 4654
Do you have a picture?
- jrkeat
I actually just found them. They are "front style terminal blocks" or "Euro style terminal blocks". I had despaired after looking through most of the connectors in the DigiKey catalogue.
Be careful ordering, they come in a range of pitches, and 5mm won't mate with 5.08mm (0.2") nor will 3mm mate with 1/4".
- jrkeat
My shopping list would probably be
Intel BOXD525MW $80
8 GB SATA DOM $40
60W PicoPSU $30
How would you install th OS on this system?
From a USB stick created using the Ubuntu startup disk creator and the LinuxCNC LiveCD image (In fact I have done so twice)How would you install th OS on this system?
- jrkeat
What would be the standard circuits for doing the voltage conversions? In particular, what would be a standard way to convert the inputs from 5v (the spindle and tool changer signals are actually 3.6v) up to 24v?
of the field I/O)
Can you describe the spindle and tool changer signals, that is, their
direction and function?
- jrkeat
First, the 7I76s step and dir signals are differential 5V (they are not part
of the field I/O)
That's great!
I haven't studied the spindle and changer circuits, but I'll tell you what I think I know without having them in front of me. There are two signals for each. For the spindle, there is a pair of optical encoders, one going on and off perhaps 100 times per revolution and one that goes once per revolution. These are debounced, and alternate between 0 and 3.6V. The tool changer is similar, with one firing for each of the 6 tools, and a second firing once per revolution.
