retrofit on EMCO PC turn 55
14 years 3 months ago #22206 by PCW
Replied by PCW on topic Re:retrofit on EMCO PC turn 55
OK the first sounds like a standard one channel spindle plus index encoder so should connect to the 7I76s encoder input directly
The tool changer inputs may either need a level shift or perhaps a trick with the 7I76s analog inputs
14 years 3 months ago #22219 by jrkeat
I can easily convert them to 24v with a transistor and a resistor (resulting in inverted output), but I had imagined there would be some super-standard IC with a Vcc of 24v.
14 years 3 months ago #22222 by andypugh
ULN2003 ?
14 years 3 months ago #22230 by PCW
Note that the spindle encoder needs to go the the 7I76 encoder inputs, so you really only have 2 inputs to convert
Since these are on the tool changer and are slow, I would be tempted to do a zero hardware patch
and connect them to inputs 0 and 1 on the 7I76 and read them as analog voltages, then put the analog
voltage through the compare component to get a bit (set threshold to 1/2 way up or 1.8V)
Eventually when we have 5V input options in the firmware this can be cleaned up
14 years 3 months ago #22233 by chuck1024
The Emco spindle encoder has an index pulse and phase A which is 100 pulses per rev. In my original wiring I used a 7409 open collector to level shift from the 5 volts to the G540 inputs which contain a +12 volt internal pullup. After looking at a datasheet it appears even +12 is exceeding the 7409 specifications of max output voltage.
When I added a second parallel port, I connected the spindle outputs and tool turret outputs directly to the second parallel port without a BOB because they are 5 volt signals and have the internal signal conditioning circuitry.
14 years 3 months ago #22247 by bobinater
Chuck
I have an EMCO PC turn 50 which is pretty much the same as the turn 55 i think, except maybe the spindle motor on yours may be three phase, is that correct? Mine is all single phase 110V
any way I am still running the fan0t control and have always had trouble with the tool turret, when I program a tool change it will try to change and then error out, all it says is fatal error?
any idea what that may be caused by, I would like to sell this lathe but I may have too much money tied up in it to sell with out it working correctly.
if you have any pointers about the turret please let me know,
Bob
Time to create page: 0.072 seconds
