5 Axis ParPort Stepper Setup with RTCP
11 years 1 month ago #62399 by andypugh
Replied by andypugh on topic 5 Axis ParPort Stepper Setup with RTCP
marq_torque wrote: i did added A axis but no luck ....both time same error triggered
It looks like another module (probably lp) has claimed the parallel port.
lsmod should answer the question as to which, and then you can usemodprobe to remove the offending module, then try again. If that works then you can blacklist the offending module.
en.wikipedia.org/wiki/Modprobe
The following user(s) said Thank You: marq_torque
11 years 1 month ago - 11 years 1 month ago #62405 by marq_torque
Replied by marq_torque on topic 5 Axis ParPort Stepper Setup with RTCP
Sorry for late reply, actually my previous emc setup ran on onboard PP. On this system I was using PCI PP... So it was difficult to setup in linux a little bit. So changing my board and updating what will happen then needed link and pivotpoint configuration.
Regards,
Last edit: 11 years 1 month ago by marq_torque.
11 years 1 month ago #62410 by marq_torque
i tried board with Parallel port, no luck .... now will be trying search how its occupied
11 years 1 month ago #62417 by Todd Zuercher
Replied by Todd Zuercher on topic 5 Axis ParPort Stepper Setup with RTCP
Have you correctly identified what the address of the PCI parallel port is?
11 years 1 month ago - 11 years 1 month ago #62427 by marq_torque
@andypugh : i did set all stuff including homing sequence to all setup from 5axis sample reference, thanks a lot mate.
@Todd : thanks, i did changed PP type in BIOS to EPP and also updated to latest version i.e. EMC 2.7.0
Finally i am set to run stepper with 5Axis Skin, all set now. all i needed to do is how to change joints details, sample skin have B/C Head when my configuration is XZ axis B Head C table, now i am stuck where to dig.
11 years 1 month ago #62450 by andypugh
Time to create page: 0.260 seconds
