- Thank you received: 3
5 Axis ParPort Stepper Setup with RTCP
- marq_torque
Ah, yes, I forgot it has a Y axis that you don't have.
and also its syncing tool tip with Y axis and C axis not in XZ axis !
- marq_torque
andypugh wrote:
Ah, yes, I forgot it has a Y axis that you don't have.marq_torque wrote: i tried maxkins. it has connection with C axis and Tool tip
found one weird error when was MDi B axis = "linear move on line0 would exceed joint 2's positive limit"
Line 0 just means MDI. It probably means that there is something wrong with the kinematics calculations to that it returns a very large number for the Z correction.
Sir any guidance where to dig now ?? :side:
marq_torque wrote: Sir any guidance where to dig now ?? :side:
Feed numbers into the calculations by hand, see if they come out the same in reverse.
I would use a spreadsheet for this. You will need to find the s2r functions in posemath.c (I think) in order to do this.
- marq_torque
Where to find this file ?? and actually i am "0" in C ...
marq_torque wrote: Where to find this file ?? and actually i am "0" in C ...
Don't worry about not knowing C yet. I didn't know it until I decided that LinuxCNC needed to support 3-phase motors.
All the source code can be found here:
github.com/jepler/linuxcnc-mirror
Specifically
github.com/jepler/linuxcnc-mirror/blob/4...posemath/posemath.cc
(Which is C++ and that confuses me)
andypugh wrote: github.com/jepler/linuxcnc-mirror/blob/4...posemath/posemath.cc
Forget that, it has just been pointed out to me that the definition of s2r is right there in the kinematics file.
