- Thank you received: 3
5 Axis ParPort Stepper Setup with RTCP
- marq_torque
11 years 1 month ago #62534
by marq_torque
Replied by marq_torque on topic 5 Axis ParPort Stepper Setup with RTCP
If you look them two machines, i have already XYZBCW configured 5Axis Kin working now, and what i am trying to do is, as another picture of machine. it says XZB are independent, and C is having no relation with tool length compensation with B axis in my configuration Head is having only One rotary axis is B and its compensated as per tool length and move XZ accordingly.
- marq_torque
11 years 1 month ago #62535
by marq_torque
C axis is Workpiece, Rotary table. so i can not use this C axis In head !
11 years 1 month ago #62536
Replied by andypugh on topic 5 Axis ParPort Stepper Setup with RTCP
You probably need to replace the C-axis terms in the equations with 0 then, ie edit lines 44 and 65 here:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...80e5de935e15;hb=HEAD
So that axis C / joint 5 is replaced by a constant 0.
You might be able to compile the edited kinematics file with halcompile.
The following user(s) said Thank You: marq_torque
- marq_torque
11 years 1 month ago #62537
by marq_torque
alright andypugh,
now i am confused ... 0 or 1 ??and what if i delete whole line ?? i mean i am not getting how to !! sorry ...
11 years 1 month ago - 11 years 1 month ago #62538
0. I think. Possibly 90 or 180 or -90. It depends.marq_torque wrote: now i am confused ... 0 or 1
If you delete the whole line then the kinematics won't work at all.and what if i delete whole line ?? i mean i am not getting how to !! sorry ...
Last edit: 11 years 1 month ago by andypugh.
- marq_torque
11 years 1 month ago #62539
by marq_torque
but i need c axis to moving simultaneously with xzb
Time to create page: 0.631 seconds
