- Thank you received: 5
Yes, I think that is the intended behavior but I don't have a system to actually verify this.But after orient is complete spindle.0.is-oriented is low. Even if spindle stop exactly on orient position.
Depending on the inertia of the spindle and the spindle drive I would expect that to be a problem and I don't really know how to deal with that if the spindle drive cannot get the spindle to stop quickly enough (unless maybe with a mechanical brake).Still play with orient pid but often after orient is complete spindle turn little and is out of orient.tolerance.
Sounds correct.Spindle-at-speed is still High
spindle.0.index-enable After start rigid tapping is set to High but after hit index is set to Low and dont go to High anymore.
