Mill atc configuration
3 years 2 months ago - 3 years 2 months ago #279577 by Aciera
Replied by Aciera on topic Mill atc configuration
Ah ok, thanks for the edit, because that had me really confused
Last edit: 3 years 2 months ago by Aciera.
3 years 2 months ago #279578 by Aciera
I'm sorry there seems to have been a misunderstanding at some time because
if your hm2_5i25.0.encoder.04.position already counts from 0..1 we don't want the
'scale.orient' component.
So in your hal file change this:
# Encoder position into orient component and orient pid
setp scale.orient.gain 0.004347826
net spindle-revs scale.orient.in
net spindle-revs-scaled <= scale.orient.out orient.position orient-pid.feedback
to this:
net spindle-revs orient.position orient-pid.feedback
You can also remove the 'loadrt' and 'addf' for scale.orient.
3 years 2 months ago #279583 by Artur_1617
Replied by Artur_1617 on topic Mill atc configuration
I make the changes.
Today I try this before:)
But still orient want to go to index.
orient-pid.command and orient command is still 0
Screen with orient on
File Name: Frezarka_z...9-01.hal
File Size:17.19 KB
3 years 2 months ago #279586 by Aciera
Hm, not sure, could you add 'orient.poserr' to the halshow?
3 years 2 months ago #279587 by Aciera
Ok, it's taken me a long time but I think I found the problem:
Try and add this to all the 'addf' lines in your ini:
addf orient servo-thread
3 years 2 months ago #279588 by Artur_1617
With orient on or off is still 0
Time to create page: 0.218 seconds
