Mill atc configuration
3 years 2 months ago #279544 by Aciera
Replied by Aciera on topic Mill atc configuration
Then you will need to go back an find out why orient-pid.feedback is wrong. Turn the spindle by hand, watch encoder.04.position and .counts and verify that those are reset on index then verify that .feedback is also zero on index and counts from 0..1 for 0..360° of rotation.
The following user(s) said Thank You: Artur_1617
3 years 2 months ago #279562 by Artur_1617
Replied by Artur_1617 on topic Mill atc configuration
Encoder.04  is reset on index and feedback is 0 and start turn the spindle growing to next index pulse and set to 0.
I think problem is any change in orient-pid.command and orient.command is still 0
3 years 2 months ago #279568 by Aciera
Yes but does 'orient.pid-.feedback' grow from 0 to 1 in one revolution? Theoretically it should get to 1.0 and then go to 0.0 but that may be difficult to do by hand.
3 years 2 months ago #279570 by Artur_1617
Before we make scale orient.pid-feedback going from 0 to 1 and set to 0
Now with scale go from 0 to 0.00434782 and set to 0
3 years 2 months ago #279571 by Aciera
so there is clearly a problem but I'm a bit confused now.
If you look at 'hm2_5i25.0.encoder.04.position', what value does it count to in one revolution of the spindle?
3 years 2 months ago - 3 years 2 months ago #279574 by Artur_1617
Encoder.04.position go from 0 to 1 and on index is set to 0
Last edit: 3 years 2 months ago by Artur_1617.
Time to create page: 0.306 seconds
