Mill atc configuration
3 years 2 months ago - 3 years 2 months ago #278479 by Artur_1617
Replied by Artur_1617 on topic Mill atc configuration
When start M19.. spindle dont turn, relays dont on.
See in halshow start orient-pid.enable etc.
orient-pid.output change to 80  is max value from maxoutput
Before start spindle.0.orient-angle and orient.angle is set to 0  after M19 is set to 50 and dont change. Must close linuxcnc and value is set to 0 again
In ini Set P6000, I300, D90
Screenshots from halshow before orient and with orient ON and connection from orient-pid.command
File Name: Frezarka_z...8-19.hal
File Size:17.14 KB
File Name: Frezarka_z...8-19.ini
File Size:6.2 KB
What more I can do?
Last edit: 3 years 2 months ago by Artur_1617.
3 years 2 months ago #278520 by Aciera
Replied by Aciera on topic Mill atc configuration
Looks like the orient-pid is suddenly working now so following the pid-output downstream it seems you have commented out the connection to the wcomp input:
#net orient-pid-output orient-pid.output => wcomp.0.in
That would explain why nothing is happening at the spindle.
The following user(s) said Thank You: Artur_1617
3 years 2 months ago #278523 by Artur_1617
Must unlink    #net spindle-orient-output    orient-pid.output  =>  mux2.0.in1
After link          net orient-pid-output orient-pid.output => wcomp.0.in
With M19.. start on relays cw/cww   dependend of orient-pid.error positive/negative
How to connect  #net spindle-orient-output    orient-pid.output  =>  mux2.0.in1  and  net orient-pid-output orient-pid.output => wcomp.0.in without error?
3 years 2 months ago #278528 by Aciera
Ah yes. Since you have already connected 'orient-pid.output' to the signal 'spindle-orient-output' with this line:
you need to remove the 'orient-pid.output' pin name from the line that reuses the signal name
So change this:
To this:
net orient-pid-output => wcomp.0.in
3 years 2 months ago #278530 by Artur_1617
After change this.
Relays stop working.
3 years 2 months ago #278531 by Aciera
Maybe add all the pins of 'wcomp.0.' to the halshow so you can actually see what is going on.
If you attach your current hal file I can have a look at what you did.
Time to create page: 0.477 seconds
