Mill atc configuration
3 years 2 months ago #278059 by Artur_1617
Replied by Artur_1617 on topic Mill atc configuration
Now linuxcnc start without error.
But after M19.. spindle dont turn and any relay cw/ccw on.
And orient-pid.output still zero
screenshots after M19
3 years 2 months ago #278062 by Aciera
Replied by Aciera on topic Mill atc configuration
Looks like your orient-pid is not doing anything. Can you post your ini file so we can see what you have set these values to:
setp orient-pid.Pgain [TUNE]P
setp orient-pid.Igain [TUNE]I
setp orient-pid.Dgain [TUNE]D
setp orient-pid.bias [TUNE]BIAS
setp orient-pid.FF0 [TUNE]FF0
setp orient-pid.FF1 [TUNE]FF1
setp orient-pid.FF2 [TUNE]FF2
setp orient-pid.deadband [TUNE]DEADBAND
setp orient-pid.maxoutput [TUNE]MAX_OUTPUT
The following user(s) said Thank You: Artur_1617
3 years 2 months ago #278064 by Artur_1617
File Name: Frezarka_z_ATC.ini
File Size:6.59 KB
3 years 2 months ago #278156 by Artur_1617
Try to change all settings from ini P, I, D etc.
But see only change in orient-pid.output if change Bias, now is set to 80. I can put more but limit is MAX_OUTPUT set to 80 for now.
But not relays cw/ccw on, or turn spindle.
M19.. finish with TIMED OUT.
3 years 2 months ago - 3 years 2 months ago #278163 by Aciera
Not sure why that pid is not doing anything really. I'm afraid I have run out of ideas for the moment.
Other than maybe check in halshow if it really has those parameters like 'orient-pid.Pgain' and so on actually loaded.
Last edit: 3 years 2 months ago by Aciera.
3 years 2 months ago #278165 by Artur_1617
I think is loaded ok
Time to create page: 0.462 seconds
