Mill atc configuration
3 years 2 months ago #278045 by Aciera
Replied by Aciera on topic Mill atc configuration
Seems that you have not connected 'wcomp.0.in' to anything.
Maybe that needs to be connected to 'orient-pid-output' so you actually get a signal from the wcomp to run the spindle forward or reverse.
The following user(s) said Thank You: Artur_1617
3 years 2 months ago #278046 by Artur_1617
Replied by Artur_1617 on topic Mill atc configuration
net orient-pid-output  => wcomp.0.in    dont change anything...
3 years 2 months ago #278049 by Artur_1617
When make M19.. and watch orient-pid.output in hall config Value dont change is still 0
3 years 2 months ago - 3 years 2 months ago #278050 by Aciera
so you will need to go and look further upstream.
Look at 'orient-pid.enable', 'orient-pid.feedback' and 'orient-pid.command'
Which brings me to the next issue as it looks like you are missing a link from 'orient.command' to 'orient-pid.command'. This would explain why 'orient-pid.output' remains zero.
Last edit: 3 years 2 months ago by Aciera.
3 years 2 months ago #278052 by Artur_1617
When connect;
net orient-command => orient.command
net orient-command => orient-pid.command
Get error orient.command is linked to o_angle  how to solve this?
On the screenshot value from orient-pid.feedback and orient.position is when turn the spindle with hand
3 years 2 months ago #278056 by Aciera
You have two options:
1.option: change your signal definition to this:
net o_angle orient.command sum2.0.in0 sum2.1.in0 orient-pid.command
2.option: reuse the already defined signal and just this line:
net o_angle orient-pid.command
Time to create page: 0.328 seconds
