homing with Phase Z encoder on MESA 7i96s
1 year 4 months ago #330763 by PCW
if you:
1. Disconnect the encoder
2. Change the index input to TTL mode
(W1 left)
3. With LinuxCNC running and halshows "Watch" tab showing
    hm2_7i96s.0.encoder.00.input-index, does the state of
    hm2_7i96s.0.encoder.00.input-index change when you ground
    the IDX+ input (TB2 pin 13)?
1 year 4 months ago #330774 by JackRay
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
i will try that tomorow
thanks
1 year 4 months ago #330808 by JackRay
So, my signal goes to true, but doesn't return to false once the wire is removed from GND. moreover, it doesn't happen every time. sometimes it works, sometimes it doesn't?
1 year 4 months ago #330810 by PCW
Is the index input jumpered for TTL MODE? (W1 left)
Unless this is done, the results will be unpredictable.
1 year 4 months ago - 1 year 4 months ago #330867 by JackRay
I'm doing the test again today
Last edit: 1 year 4 months ago by JackRay.
1 year 4 months ago - 1 year 4 months ago #330868 by JackRay
So, when I insert the wire into pin 13, the signal is on “Fasle” and when I remove it, the signal is on “True”. Without connecting Z to GND
Time to create page: 2.487 seconds
