- Thank you received: 14
homing with Phase Z encoder on MESA 7i96s
- JackRay
1 year 3 months ago #331464
by JackRay
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
now it's ok, my homing works properly. Thank you very much for your help. I now need to set it up to return to my Zero machine. Is it the Homing parmeter? or Homing Offset to apply an offset?
- JackRay
1 year 3 months ago #331973
by JackRay
Hello,
After adjusting my Z-phrase for homing, I'm looking to gain some prediction on the positioning of my.
I have a 2000 puls quadrature encoder, which gives me a precision of 0.04 mm. However, I can't get within 0.15mm.
How can I get as close as possible to the maximum resolution of my encoder?
Thank you
Thank you
- Thank you received: 5334
1 year 3 months ago #331978
Replied by PCW on topic homing with Phase Z encoder on MESA 7i96s
is this a static error? ( error when not in motion )
If so and you already have as much P term as you can set while
remaining stable, you can add some I term to eliminate the static error.
If it's a dynamic error ( error when in motion ) I would have to have a
halscope plot of the error to see whats going on.
- JackRay
1 year 3 months ago #332138
by JackRay
it's a static error. But when I put “I” > 1 I get a joint tracking error.
1 year 3 months ago #332139
Can you post a halscope plot of:
1 Joint velocity
2. Joint following error
1 Joint velocity
Time to create page: 1.784 seconds
