- Thank you received: 14
homing with Phase Z encoder on MESA 7i96s
- JackRay
1 year 3 months ago #331069
by JackRay
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
my configuration works very well on the x,y,z axes with on/off switches. homming is all done at the same time without any problem. the problem is only on this rotary axis where i have an encoder with which i want to use the Z phase to do my homing.
- Thank you received: 5334
1 year 3 months ago #331070
Replied by PCW on topic homing with Phase Z encoder on MESA 7i96s
OK, that's probably to be expected since there does not seem to be any B axis home switch
and you have setup a homing scheme that requires that switch.
If you don't have a home switch on B, and you want to home to index, you need to setup
Index-only homing:
linuxcnc.org/docs/html/config/ini-homing.html#_configuration
Index-only homing:
- JackRay
1 year 3 months ago - 1 year 3 months ago #331091
by JackRay
Yes, that's what I've done. My axis is configured in my .hal & .ini files with Z pulse detection on my rotary axis ( B ), which has no switch. The problem is that I can't detect my Z pulse during homing on this axis ( B ). The hardware tests you made me do comply.
On all my other axes, homing is done correctly (with switches) in accordance with the attached documentation.
Last edit: 1 year 3 months ago by JackRay.
1 year 3 months ago #331102
Did you set HOME_SEARCH_VEL to 0 as required by Index-only homing?
Otherwise homing B will search for a home switch before searching for index.
- JackRay
1 year 3 months ago #331121
by JackRay
ok, I understood that, but how will my axis move if I don't give any speed? it will never detect my plus Z. I can't understand the logic ☺
1 year 3 months ago - 1 year 3 months ago #331125
The search velocity is the speed when searching for the first
home switch actuation, the latch velocity is the velocity used
for for the actual homing switch/index move so only the latching
velocity is needed in this case.
Basically, Index-only homing is specified by setting the search
velocity to 0. (as the homing documentation specifies)
Last edit: 1 year 3 months ago by PCW.
Time to create page: 1.243 seconds
