homing with Phase Z encoder on MESA 7i96s
1 year 4 months ago - 1 year 4 months ago #331004 by JackRay
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
so I tested it and switched the red button to yellow. and it turned red at the same position when I turned my encoder.
Last edit: 1 year 4 months ago by JackRay.
1 year 4 months ago - 1 year 4 months ago #331009 by PCW
OK that means that index is working as expected, so if homing
to index fails, its likely a homing setup issue.
Last edit: 1 year 4 months ago by PCW.
1 year 4 months ago #331014 by JackRay
what do you mean by a configuration problem, in a .hal file?
1 year 4 months ago #331015 by PCW
Homing configuration is in both the hal file (index and home switch handling) and the ini file
(type of homing, directions, speeds etc)
linuxcnc.org/docs/html/config/ini-homing.html
1 year 4 months ago #331045 by JackRay
Are you saying that my .ini file is misconfigured and that's why I can't detect my Z homing?
1 year 4 months ago #331049 by PCW
Did you check the home switch operation?
That is, does  joint.2.home-sw-in go true (change from red to yellow in halshow)
when you manually trip the home switch?
Time to create page: 2.482 seconds
