- Thank you received: 5334
homing with Phase Z encoder on MESA 7i96s
1 year 6 months ago #325817
Replied by PCW on topic homing with Phase Z encoder on MESA 7i96s
Unfortunately Autotune programs do no adjust the feedforward or deadzone terms so fairly useless
in real world situations.
I suspect for the best performance of a position control (stepgen or Ethercat or whatever) with an added
linear feedback device, you would need two PID loops, the local high bandwidth position loop plus a lower bandwidth
PID loop using the linear encoder feedback. This could be done in hal with two PID components with their outputs
summed.
summed.
- JackRay
- Thank you received: 14
1 year 6 months ago #325950
by JackRay
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
Yes thank you but then I have no idea how to do it .
Regards
Regards
1 year 6 months ago #325952
At the minimum you should:
Expand the ferror limits as explained above.
Learn to use halscope.
It will not really be possible to tune without using halscope
regardless of the hal setup.
- JackRay
1 year 6 months ago #326191
by JackRay
but I know how to use the halscope. I know how to read the curves, but I don't know which parameter to adjust when, for example, I have oscillations in the error.
1 year 6 months ago #326192
Can you post a plot that shows this oscillation, including the velocity and the ferror?
- JackRay
1 year 4 months ago #330320
by JackRay
hello,I've managed to set my PID.I've mounted an encoder directly on my machine B axis. My encoder is of the phase type A+,A-;B+,B-;Z+,Z-.the feedback is correct on my axis position. However, it's impossible to detect my Z0. I have a 7i96s and I've connected my two Z+,Z- wires to pins 13 & 14 of TB2 on my card. My .hal file is correctly configured for homing with this Z phase. I've tested 5 encoders of the same type. but I can't find the Z pulse.Is there a trick? Can anyone help me? Thanks
Time to create page: 0.134 seconds
