Retrofitting a TOS FNG 32 NC
30 Jan 2023 21:47 #263293 by Henk
Replied by Henk on topic Retrofitting a TOS FNG 32 NC
I would suspect that the drive is not getting feedback from the tacho on the motor.
You can make the P in your tuning 0 and only use Ff1 so that linuxcnc doesn't correct the position loop and see if the motor wants to run away. That normally means that there is tacho issues.
Be carefull though. It can run away and crash. Make sure that the following error will disable the drive. Better to take the motor or belt off before doing this.
The following user(s) said Thank You: Kevin_Pawlus
Moderators: piasdom
Time to create page: 0.126 seconds
