- Oxbown
2 months 1 day ago #349154
by Oxbown
Replied by Oxbown on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Hi Meister, I updated to the dev branch, but I don't see any difference. Is there any way to sniff the Modbus network?
- meister
- Thank you received: 502
2 months 1 day ago #349155
by meister
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
new dev update:
go to mbus plugin-config and set the new debug flag
hope that help's
hope that help's
- Oxbown
2 months 23 hours ago #349156
by Oxbown
I ran a couple of tests, and the raw Modbus data makes sense. The board's response is OK, and the data corresponds to the DIs that are ON.
Seems that the mistake is in the LinuxCNC HAL config.
IN1
> MODBUS_TX(mbus0): 1 3 0 192 0 2 196 55
MODBUS_RXmbus0: 1 3 4 0 1 0 0 171 243
IN2
MODBUS_RXmbus0: 1 3 4 0 2 0 0 91 243
IN1 + IN2
MODBUS_RXmbus0: 1 3 4 0 3 0 0 10 51
- meister
2 months 22 hours ago - 2 months 22 hours ago #349158
by meister
i think the problem is, your device returns 4 bytes, not the requested 2 ?!?!
you need to pull dev to incrase the values, with my simulation it works, but it's a workaround,
i will write a fix, to read the values in the right order and ignore the last 16bit's
01 03 00 192 00 02 196 55
01: The SlaveID
03: The Function Code 3 (read Analog Output Holding Registers)
00 192: start register
00 02: number of bytes
01 03 04 00 02 00 00 91 243
01: The SlaveID
04: The number of data bytes to follow
00: The contents of register 192
02: The contents of register 193
00: The contents of register 194
00: The contents of register 195
please try to change the 16 'values' to 32
Last edit: 2 months 22 hours ago by meister.
- meister
2 months 21 hours ago #349159
by meister
oh, no, my fault, i send number of bytes, not number of registers
- meister
2 months 21 hours ago #349160
by meister
I hope I’ve managed it now; it’s a bit tricky without the hardware
please set back to 16 values, update dev and try again
Time to create page: 0.398 seconds
