- Thank you received: 125
Kinematics... again:/
- chimeno
7 years 10 months ago #122058
by chimeno
Replied by chimeno on topic Kinematics... again:/
Hello Andy,
sorry but I just can not understand "Corners are correct in the space of the machine", you mean the angles of the pieces placed in vismash?
Regards, Chimeno
Regards, Chimeno
7 years 10 months ago #122070
Replied by andypugh on topic Kinematics... again:/
I didn't say "corners" I said angles.
If you look at the model and look at the joint angles in the GUI does 90 degrees look like 90 degrees?
- chimeno
7 years 10 months ago #122101
by chimeno
Hello Andy,
sorry I was wrong to write, been looking at the GUI but I am not able to see it ... I think it is 90ยบ, but in the vismash it is not reflected.
Thank you
Chimeno
andypugh wrote: I didn't say "corners" I said angles.
Hello Andy,
Thank you
Chimeno
7 years 10 months ago #122102
Try jogging to zero and 180 too, those should be fairly clear.
Unless the joint angles in the model match the commanded positions the Vismach preview will be inaccurate.
The following user(s) said Thank You: chimeno
- chimeno
7 years 10 months ago - 7 years 10 months ago #122107
by chimeno
Last edit: 7 years 10 months ago by chimeno.
7 years 10 months ago #122112
It clearly starts with the angles at 0,0,0,0. And if you look at the model they are x,0,90,90.
If you fix that then it might work properly.
Time to create page: 0.142 seconds
